Genmitsu ProVerXL 4030 CNC
Hey guys,
I am looking to buy a PROVerXL 4030 V2 and use it with the 4th axis. There is the “Rotary Module Kit for PROVerXL 4030 V2 CNC Router” (SKU: 101-63-4AXIS-43V2) on you website. Do I need just this upgrade or is there anything else?
I think I’ve read that there is a problem with the Rotary Module Kit for the PROVerXL 4030 V2 since there is no 4th axis connection?
Thanks a lot, S
Hey there,
It’s great to hear you’re looking to expand the capabilities of the PROVerXL 4030 V2 with the 4th axis.
  1. Do you need anything else? No, you only need the Rotary Module Kit (SKU: 101-63-4AXIS-43V2). This upgrade kit is designed to be plug-and-play with the V2 machine, and no additional accessories or external drivers are required for setup.
  2. Regarding the connection issue: The problem you read about—where there was no dedicated 4th axis connection—was specific to the original PROVerXL 4030 V1. We took that feedback seriously when developing the newer generation. The V2 version does not have this issue; it is fully compatible and includes the necessary interface to support the rotary module seamlessly.
You should be all set to go with just that kit!
