[Open Highlights] Orbbec Gemini 335: Indoor/Outdoor Depth Sensing, Redefined
Hey everyone, sharing a quick update on Orbbec’s Gemini 335, a flagship in the Gemini 330 depth + RGB camera family. Built for reliable performance across lighting conditions, indoors and out, it’s a solid option for robotics, AR/VR, mapping, and more.
What makes the Gemini 335 stand out
  • Dual stereo tech for robust depth in varied lighting: active + passive stereo ensure dependable depth data whether indoors, outdoors, or mixed environments.
  • Outdoor-ready with IP5X dust protection, plus seamless indoor performance.
  • Edge processing power: built-in depth and RGB processing with the MX6800 ASIC to keep latency low and on-device decision making fast.
  • Wide field of view: 90° horizontal x 65° vertical for broad scene coverage.
  • Precise multi-device synchronization: synchronized depth and color frames, easy to coordinate across several cameras if you’re building a larger setup.
  • Simple integration: easy setup with the Orbbec SDK, and consistent data quality from pitch black to bright daylight.
Why it matters
  • A single camera that performs reliably in dynamic environments, reducing the need for environment-specific hardware.
  • Compact, synchronized perception that’s great for constrained spaces and multi-camera rigs.
Who’s it for
That’s all for this share. What practical applications would you explore with the Gemini 335’s indoor/outdoor depth capabilities?
