Meet the Seeed Studio reTerminal E1001 / E1002 — an open‑source, full‑color ePaper dashboard designed for always‑on information displays with ultra‑low power consumption. It’s ideal for unattended home or office dashboards and no‑code IoT interfaces.
What’s inside
- Display: 7.3‑inch open‑source ePaper display, vibrant visuals, crisp text, and extremely low power draw
- Battery life: built‑in 2000 mAh battery; up to 3 months in deep sleep mode with a 6‑hour refresh cycle
- Processor: ESP32‑S3 MCU for smooth performance and quick onboarding
- No‑code UI: SenseCraft HMI — drag‑and‑drop UI builder to design and deploy dashboards in minutes (no coding required)
- Compatibility: Home Assistant via ESPHome, TRMNL E‑ink dashboards, Arduino, ESP-IDF
Why it matters
- Ultra‑low power, long‑life dashboards mean fewer chargers and maintenance, perfect for unattended displays in homes, offices, or retail.
- No‑code UI design accelerates prototyping and deployment, letting you visualize sensors, schedules, or status at a glance.
- Broad software compatibility makes it a flexible choice for both makers and developers—from plug‑and‑play dashboards to custom IoT apps.
Use cases
- Home dashboards: visualize temperature, humidity, and energy data with real‑time updates
- Office/retail signage: persistent, colorful status boards and schedules with minimal maintenance
- Educational or prototyping: quick experiments with UI design and data mapping
If you want a stylish, energy‑efficient, no‑coding path to robust dashboards for home, office, or public displays, Seeed reTerminal E1001 / E1002 is worth a look.
That’s all for this share. What will you build with SenseCraft HMI? Share your ideas!
