If you’re building Meshtastic or any remote LoRa deployment, Seeed’s SenseCAP Solar Node P1‑Pro is a neat “drop it in the field and forget it” option. It bundles everything into one compact, solar-powered unit for places where cell/Wi‑Fi simply don’t exist.
What it is
A solar-powered communication node that combines XIAO nRF52840 Plus (controller) + Wio‑SX1262 LoRa + XIAO L76K GPS in a single outdoor-ready package.
Why it’s worth a look
Off-grid power built in: 5W solar panel + 4×18650 batteries (3350mAh each) for long unattended operation
Meshtastic-ready: ships pre-flashed with Meshtastic firmware—join your mesh out of the box
Long-range LoRa: rated 8–9 km in open areas; works well as a node or repeater to extend coverage
GPS included: real-time positioning and live location sharing for outdoor ops / tracking
Expandable sensors: Grove interface for add-ons like temp/humidity/motion—easy environmental monitoring builds
Nice extras
Optional 860–930MHz 3dBi fiberglass antenna if you want more gain, plus a simple RF cable/quick mount workflow for fast installs.
Use cases
Off-grid messaging + location for outdoor adventures, Meshtastic mesh expansion, field/asset tracking, STEM demos, and remote environmental monitoring.
Check Now: Seeed Studio SenseCAP Solar Node P1-Pro for Meshtastic GPS Battery Included
That’s all for this share. What would you deploy the SenseCAP Solar Node P1‑Pro for—mesh expansion, tracking, or remote sensing?
