I am planning to use the Seeed Studio Wio Tracker L1 for a project and want to ensure fail-safety by running it with a solar panel. Could anyone clarify the following:
What are the specifications required for the solar panel?
Can the panel be connected directly to the board (is the charging electronics onboard)?
Is there a schematic or pinout diagram available?
Thanks!
Hi R, great question! Using solar power is a perfect use case for the Wio Tracker L1. Here are the technical details you need:
1. Solar Panel Specifications
2. Direct Connection
- Yes, the board has onboard charging management. You can connect a compliant 5V solar panel directly to the solar port.
3. Schematics & Pinout You can find the full schematics, including all pin definitions, in the official documentation here: Download Wio Tracker L1 Pro Schematics (PDF)
Good luck with your solar-powered project!
